Anonymous-0
Hi Guys.
I took a set of liners out of a Farmall H. I have a set of almost new liners that I want to put in, how do you guys put them in ? thanks for any help you can give me.
Ken.
clean the outside of the liners so there is no rust on them and they are smooth, then i put the liners in the freezer overnight. clean up the cylinder bores in the block so they are smooth and rust free. just before putting the liners in , i wipe the bores down with kerosene to lube them, then use a stout wood block and a mallet and drive the liners in. they should go in easy when they come out of the freezer, it shrnks them just enough.
I did pretty much the same, froze the liners, put a electric heater under the block. The liers dropped right in.
