liquid weight
ANYBODY HAVE IDEAS TO BRING WEIGHT UP WITHOUT USING CACEUM CLORIDE (SORRY I CANT SPELL). DON'T WANT TO USE WHEEL WEIGHTS BECAUSE I HAVE SPOKE WHEELS. I'M ABOUT 600 POUNDS LIGHT FOR MY FIRST WEIGHT CLASS.THANKS FOR ANY IDEAS.ALAN
I was told to use beet juice. I guess it won't freeze and its cheap. So I have been told.
I have no clue where you can get it!
Shaggy
were i pull no flued is alowed good to use we got new 4630 no flued added same weight in wheels it would"nt pull the plow had flued added pulled get look wheghts of to cultavat next spring did"nt want to put weghts back on so tried to plow with no weights just flued pulled plow fine so when i pulled pickups had set of tires with water in them stock 460 f250 only had $2000.00 in truck out pulled some trucks with $10,000.00 in moter they always said don"t know how you get that ford to pull so good at 1800rpm
go to the Firestone web site they have a chart for your size tires how much it will weigh when you add fluid.
I started to correct the errors in syntax,grammar and the run on sentences. However your message is so disjointed one can not be certain of your intentions.
No wonder America is going for a skid. At least 1/3 of the population failed grade eight.
Where I pull no fluid is allowed.
We purchased a new 4630 no fluid added same weight in wheels it wouldn't pull the plow had fluid added pulled get look weights of to cultivate next spring didn't want to put weights back on so tried to plow with no weights just fluid pulled plow fine so when i pulled pickups had set of tires with water in them stock 460 f250 only had $2000.00 in truck out pulled some trucks with $10,000.00 in motor they always said don"t know how you get that ford to pull so good at 1800rpm
I just use plan water. During winter park with valve stems on top and don't use tractor when it is below zero. We get freezing temperatures for 4-6 weeks. Done this for years and no problems yet.
go to a local auto salvage yard and get there used anti freeze some give it away some charge 1 or 2 dollars a gallon pretty cheap weight
beet juice only works on red stuff o it is really used cause it dont eat rims up i hear them red tractors have plenty of problems any way so i guess you dont want them rusting
Hey how is it going down in the southern part of this great state?
I still want to bring a few red ones down to pull but we are a little short on change at the moment but the summer isn't over yet!
Yea, #12 shot, with no tube. Just don't breed because your kid will drag its head across the floor from the pb poisoning! Maybe tungsten, or some other waterfowl shot. Then it'll wear thru the rims instead of rusting.
If you don't want to change your rims, make an adaptor that clamps to the axle with 2 studs sticking out of and a big tube in the cener of it to put your wheel weights on.
