lite weight front
Check out Carl Davis JD B.
He is about as light as you get!
Look at Hook Mag web page photos at most NATPA Pulls
Cliff S
This front end assembly is 165 lbs lighter then the original narrow front.
Sure. And then add three suitcase weights up there to make up for it ? Seems futile to me. IMO if you can't get it off the back why bother.
Those three weights are movable weight.It moves that weight farther out front when you do get a good bite. You won"t always need it up there and you can move it to the back when you need to.
This is a complete assembly that is bolt on and ready to go. If one is purchased I will show you how you can lighten the year axle another 250 lbs. The model A can be very competitive in the 3500 and 3800 lb class without spending tons of money on engine work.
