Anonymous-0
I have a long 360 the motor and rear end is blue. I found a long 360 that has a gold motor and rear end. It has a loader on it . will the loader fit the blue one and why is one blue and one gold?The model# on the loader is f528 Davenport Iowa Serial# 1409 The blue 360 reads Long Taboro Nc unerversal tractor Brasov Romania Model 1563 serial #592858 And the gold one reads Brasov Romania Tractor U-350 35 1380 serial #590520 I am looking for a web site with information on the long tractors Also parts and service manuals The blue tractor looks and runs great and has low hours the gold one has set up for 3 or 4 years and has the loader on it The gold one has some missing parts and may or may not run. Thanks for any help Randy
Book shows 360 made 1977-1991. 36 hp, weight 3750 lbs.
I THINK the gold one is older. Early one may have the single lever 6 speed transmission, the later ones 2 lever 8 speed with independent pto.
I would be very suprised if the loader would not interchange. Do some carefull measuring. Note hydraulic pump hook up. The larger Longs have a plate on the rear end housing above the pto shaft that can be removed and a hydraulic pump put there. It works only when the pto is engaged.
KEH
Thanks the 360 does have the plate above the Pto and the gold wone has a pump in the same place But I now have the loader all un bolted from the gold long and have pulled off the fenders and the rear axel housing is more round and the blue one is more square and is diffrent I think I can still make something to adpt it. It looks like 2 of the big bolts that hold the fenders on will line up with the 2 on the gold one. I might be able to just use 2 bolts on each side. Thanks Randy
