NatWester
Long 610 4 cylinder - injector pump timing?
I had the injection pump and all the injectors rebuilt, engine has been rebuilt - new pistons/rings, cylinders honed, new rod bearings, and a complete gasket set- but I've got a rattle/knock that gets worse when rpms go up
Note: at idle, oil pressure is 25psi, revved up it's over 50p
1st 2: Top of the pump away from the engine all the way....
2nd 2: Top of the pump towards engine all the way....
si
I had a Long pump rebuilt years ago for a 3 cylinder tractor, a 445 I think. When I picked it up my memory says it was timed to TDC and the engine had to be timed to that position. I installed it that way and it still works. I would begin by seeing if the rebuilder timed the pump as iI describe. There are a couple of Long facebook groups that may offer some help.
