Looking for Farmall H
I know this might be a crazy thing to try but I have hope. In June I found my gpas Farmall 450, so I might as well try finding his H. His H I believe was a 46. Had a TSC wide front end put on it. With the front end it sat low in the rear end and high up front. IT had a charlynn power steering put on it and a hole cut in the hood to check the fluid for it. Also it had a live hyrualic pump put on it. Also it have a home made hydraulic valve set up on it. He always said it went to Canada so Im thinking it could be in the Northern US maybe. I know finding an H with out a serial number is like tryin to find a certain needle in a stack of needles but dont hurt to try. Any info would be appreciated.
You might add where the H was located when it was sold so the reader know and someones memory might get jolted. Good Luck hope you find it.
