Anonymous-0
lost ignition key to my D 17 series 4. Before I replace the key assembly,are all the keys for that tractor the same. I know my 7040 has a standard ignition key. Thanks Dan
Don't know about the brand new tractors but up into the 90's I think most major brands used a key that was sorta universal. IE a key for a 4430 JD will work in a 4850 etc.
Short answer is yes you should be able to buy just the key.
The key for a WD-45 matches the Briggs and Stratton key pattern blank you find at the hardware store. Might be the same for D-17.
Don"t know about the Series IV, but the III is very similar, if not the same, as a Gleaner F combine. Key has a curve in it. Not flat like the WD45. Subject came up here few weeks ago- I still haven"t checked if my III and the F/F2 are the same. Good for the todo list.
D-17"s used two different keys.
Get you series and serial number and go to AGCO and they can get you new ones.
Here is a link to find a local Agco dealer.
Dealer
curved key is a delco type. I seem to remember OEM tractor parts (IH parts) offers rounded delco keys for the farmall 300 and 400 tractors.
fastest and cheapest way would be salvage yard with gleaner combines
-karl f
