My JD2010 has sometimes really little power, exhaust a lot light blue smoke and from the cylinder head outlet a lot of white smoke.
The measured compression is really low 70-50-60-50psi.
3 from 4 spark plugs are oily and black, one (1st cyl.) is good/brown.
So far refurbished the carb, checked and adjusted ignition, new oil, cleaned/replaced all filters.
Look like there's more work to do.
Suggestions? Where to start? In what order to proceed?
Valve clearance check/adjustments?
Valve or cylinder head overhaul?
New piston rings?
Any experience and recommendation is appreciated.
New piston rings?
