I've always used Dawn dish soap on all the wet sleeve engines I have worked onI have managed to lose my bottle of Engine assembly Lube and I dont really want to use Vaseline on the O-rings on the sleeves.
Any suggestions?
I use silicon dielectric compound (Tune up grease) I use it on most o-rings.I have managed to lose my bottle of Engine assembly Lube and I dont really want to use Vaseline on the O-rings on the sleeves.
Any suggestions?
Murphy's vegetable oil soap. Right at your local grocery store.I have managed to lose my bottle of Engine assembly Lube and I dont really want to use Vaseline on the O-rings on the sleeves.
Any suggestions?
good thing u lost it as never use any oil product on them o rings! use dish soap or brake fluid.I have managed to lose my bottle of Engine assembly Lube and I dont really want to use Vaseline on the O-rings on the sleeves.
Any suggestions?
just thinking murphy's tire soap should be just tickety boo also.Murphy's vegetable oil soap. Right at your local grocery store.
yes the giant John Deere 308 liner soap will last forever. Ive been using it to install uncooperative tires lately. It works great in both cases. It is 45 bucks a bottle so I don't use it on all the tires but skid loaders with the rim guard once you use that you won't go back to the dawn or even the Murphys for that particular task.I agree with the dish soap. However, if you’ve got extra money to burn and you really want to do it by the book, John Deere sells a wet sleeve o-ring install product.
It’s more than you’ll ever use. The last time I used it, I borrowed a bottle.
Vaseline or dielectric grease is fine but wait, IH service manual for the D239 saysGo in the kitchen and steal your wife's bottle of Dawn off the backsplash.
Been thinking about that also. Them o rings in hyd couplers are oil soaked steady. I don’t see them swelled up. But “do not use oil “has been drilled in my head forever. Unless they are oil resistant like fuel hose.Vaseline or dielectric grease is fine but wait, IH service manual for the D239 says
“ Lubricate the oring with clean engine oil and carefully install oring into the crankcase groove” and “ put clean engine oil onto the sealing faces of each cylinder liner”, kinda shoots down the not to use oil theory
sleeve o rings are different material, sometimes, I know a guy that smoked a couple sleeves and pistons on a brand new overhaul in a 855 cummins using the wrong lube, he worked for IH truck shop, anyway you are pretty much always with dawn dishsoap, if in doubt go to that or reach to kit supplier, if they don't know then thats not good! Dawn or Ivory should never hurt the sleeve o rings, I have played like you say with o-rings and different lubes, heck even my rubber wedding ring, some stuff will make them swell to 3 or 4 times their normal size and some will just turn them to slime!Been thinking about that also. Them o rings in hyd couplers are oil soaked steady. I don’t see them swelled up. But “do not use oil “has been drilled in my head forever. Unless they are oil resistant like fuel hose.. Need to throw an o ring in oil and see what happens to see if they are indeed oil resistant.
Obviously there are different kinds of orings, and I’m just talking tractor sleeve orings cause if you think about it those orings are getting oil from the crankcase on the bottom of them anyway. Somewhere along the line it got drilled into a lot of peoples heads and what I quoted was straight from an IH service manualBeen thinking about that also. Them o rings in hyd couplers are oil soaked steady. I don’t see them swelled up. But “do not use oil “has been drilled in my head forever. Unless they are oil resistant like fuel hose.. Need to throw an o ring in oil and see what happens to see if they are indeed oil resistant.
Sure funny nobody ever mentions brake fluid. ??? I have used it a few times.sleeve o rings are different material, sometimes, I know a guy that smoked a couple sleeves and pistons on a brand new overhaul in a 855 cummins using the wrong lube, he worked for IH truck shop, anyway you are pretty much always with dawn dishsoap, if in doubt go to that or reach to kit supplier, if they don't know then thats not good! Dawn or Ivory should never hurt the sleeve o rings, I have played like you say with o-rings and different lubes, heck even my rubber wedding ring, some stuff will make them swell to 3 or 4 times their normal size and some will just turn them to slime!
