David G.
I have Int. 784, I am trying to replace lube pump in lower compartment, I'm at the point where I need to remove two screws that secure pump, manual says remove two screws in bottom of rear frame which secures pump, I found one hole and I did remove one screw, is there another screw in same hole above the screw I removed or is there another hole?
As I said above I removed one screw from one hole I look up in the hole and cannot understand what I'm seeing and I don't see another hole.
Keep in mind this tractor had a previous owner and I have no idea how repairs were done and who did repairs.
Any all help appreciated,
David
There is supposed to be another screw in same hole. First screw locks second screw which is locking pump in position. May not have been assembled correctly using two screws but then the pump should be able to move if no second screw.
Thanks Pete, tried tapping on pump with hammer and it didn't move. The screw I removed had allen head and was pointed on other/upper end, will try looking in hole again.
