I have Int. 784, I am trying to replace lube pump in lower compartment, I'm at the point where I need to remove two screws that secure pump, manual says remove two screws in bottom of rear frame which secures pump, I found one hole and I did remove one screw, is there another screw in same hole above the screw I removed or is there another hole?
As I said above I removed one screw from one hole I look up in the hole and cannot understand what I'm seeing and I don't see another hole.
Keep in mind this tractor had a previous owner and I have no idea how repairs were done and who did repairs.
Any all help appreciated,
David
David
