LX565 skidloader running weak
Anonymous-0
I have a New Holland LX 565 skidloader. This morning while I was trying to plow snow it ran very weak. Even after it warmed up. It was cold here in SE Wisconsin but not too bad 12 degrees. I removed the air filter and tried to run it wthout it as I know I need a new air filter as the light came on and I blew it out and it came on again a few days ago. I'm getting a new air filter today. However it still ran weak. We are running blended fuel. What could the problem be???? Any help would be great.
Check that the vent in the fuel cap isn't plugged by removing the cap and seeing how it runs.
If that doesn't change anything, change both the inline filter above the tank next to the left side panel and the spin-on filter inside the back door.
One of those is likely to correct the problem unless it's gelling really badly...
Rod
Good chance your fuel is gelling or you have water in the fuel filter. Check for a drain on the filter, 'borrow' your wife's hair dryer, thaw out the filter, drain it. My Gehl with a Kubota is the most miserable diesel to prime, so rather than replace the filter in the winter- I use the afore-mentioned trick. Also put some anti-gel in the fuel tank.
