M valve clearance
Dan W MN
HI all
I'm getting closer to finaly starting my M after an overhaul. does anyone have hot and cold valve clearances handy?
Thanks!
(quoted from post at 19:16:55 11/13/10) .017 hot, and .020 cold. i think rusty farmall gave me the cold setting. worked real good.
Yes, that 0.020" figure is what I came up with simply by guessing. I just couldn't get my ol' M warmed up enough, and when I set the valves at 0.017", the engine would not run good when it DID get warmed up, so I set the valves at 0.020" while the engine was cold, and it worked out pretty good. I've had other folks tell me that 0.022" COLD works out well also.
Oh someone needs to come clean, where are you guys getting 17 20 valve clearance. Every manual i read says 12 cold. I've just did a overhaul and wanting to specs but surely dont know what to believe. Mine runs good at 12 but a bit hard to start cold. Also have some blow by no smoke on exhaust just valve cover. Hoping wrong valve clearance will settle it.
Oh someone needs to come clean, where are you guys getting 17 20 valve clearance. Every manual i read says 12 cold. I've just did an overhaul and wanting to specs but surely dont know what to believe. Mine runs good at 12 but a bit hard to start cold. Also have some blow by no smoke on exhaust just valve cover. Hoping wrong valve clearance will settle it.
Where are u getting .017 ? Like to see them spec’s. Plus there never is a cold spec listed as spec’s are usually listed .017 h the smaller tractors like a b and c’s are listed as .014 h. If you’re setting them .012 h that’s too tight. And once the engine gets to temp your probably at .009. Allis charmers likes to use tight spec’s. Like that.
but too loose and you’re causing excessive wear from the valve beating on the seat
I agree with some additional wear on the valve stem end and valve train. In my opinion the only time valve lash affects the valve and seat is when it gets to tight holding it open. The hot gases passing between the valve a seat contribute to valve burning. I suppose an extremely loose adjustment to where the valve is one opening 1/2 it’s normal lift would also be detrimental. It’s “clacking” would be telling you there is a problem.
valve cooling is the amount of time they stay seated. so adjusting valves you want to be at the loser end of the spec. of course staying in spec. as the valve seat and valve face wears the clearance will decrease. as the cam lobe and push rod and rocker wear the clearance will be greater. lots of times when you are hearing this clatter there is already a problem , beyond just an adjustment. plus give 3 feeler gauges to 3 amatures and you will have 3 different readings. setting valves requires a good feel to feel .001 difference. always better to be .001or even .002 looser than that amount tighter is the way i look at it.
Yes all true and that’s why there’s a spec
On a M, IH 4-cylinder carbureted engines service manual ISS-1031-1 gives .019 cold and .017 at operating temperature. If arms have indentations worn at contact with valve stem you may need to fudge. If worn best to regrind contacts or find a better set if much needs to come off.
Thanks, done some more searching and says 17 or 20 cold also from previous post on here. Going to adjust tomorrow. Valve clearance shouldn't be the cause of little excessive blow by but may if compression to high and going past rings. Was just overhauled and I know I should take it out when warms and hook on to disc or something to break in . Although iam not getting any smoke from exhaust at all. Plugs dry also and close to 100 compression on each cylinder. It's ran maybe 1 hour so far
When you overhauled it did you thoroughly clean the mesh inside the breather housing?
Looks like steel wool.
Here is why I am confused with your alls valve clearance specs. Makes it difficult in what to believe.
dont be confused with our spec's of .017. its correct. i dont know what manual or engine they are showing you but that is not a farmall m engine. i could see right away it was a one cylinder and the rockers are also different. there is a model M engine also but that photo is not of it either. of show us the cover and more of that manual. now i think your looking at the john deere "M" tractor engine . sure looks like it.
