m w 9 speed
M&W low range has a 20 tooth gear driving a 54 tooth constant mesh gear, same as stock M. High range has a 29 driving a 34 which speeds up 1,2, 3, 4 and reverse. You do the math.
The m w 9 speed gives you four more gears between 4 and 5 I have all paper work for mine itdoes nothing on low side 1234 stay the same the speeds are 6 7.5 9 11 MPH gives you two reveres speeds and two PTO speeds
