M w/live hyd advise please
ch0ck 430 C
I just got done adding live hyd to my Farmall M. I used the IH add-on 2way tree valve like this.
My question is: Do I need to add a pressure regulator or will be ok without?
Chock 430 C, Those valves do not have a relief valve in them so yes you have to put one in between the pump and valve. Good luck, Chuck
The SMTA with that pump and valve were set at 1000. I have my H at 1000 also it does well on the work I use it for and has run for 35 years with out any problems. Chuck
