magneto jd 50
Nothing wrong with Magnetos, they ran tractors for 70 years, plus. Just sometimes require slightly more maintenance than a distributor.
There are actually some advantages to a magneto. No battery or generator required (or working!) for the tractor to run. Later generations of magnetos are quite reliable, and the magnets are made of an alloy that does not require regular recharging, as early magnets did.
If you really don"t like the magneto, you can most likely switch it to a distributer, so I would not turn down a tractor for that reason alone.
Kurt
Every small aircraft including some small helicopters (piston powered)use magnetos. A magneto when maintained properly will keep right on ticking after a distributor has wore itself out. They are great for troubleshooting a tractor because they don't require any electrical system for power.
Scott
Farmer, For over then years Ive given Seminars on Distribuotr ignitions and Wico Magnetos, and can tell ya I get more questions and people seem to have more problems operating/timing/troubleshooting and repairing their mags then their distributors.
The deal is, if youre not at all electrically and mechanically inclined to pull routine maintenance and repair, its true a Magneto may cause you more heartburn then a battery powered (especially a Delco unit) coil ignition as they are more forgiving then a Mag,,,,,,,dont have all that impulse spring wind n trip problem,,,,,, plus the distributor has a better RPM variable spark adance system and can produce more spark energy.
HOWEVER the mag doesnt need or use any battery energy which can certainly be an advantage. If you go with say a Wico X Model Mag they are reliable and easy to get parts for.
Yout tractor, your money, your choice
John T
I agree. I have a '37 WC that had a distributor on it when I got it. For general convenience ( to me) I put an old Fairbanks RV4 mag on it and now I start it with a crank. With a few turns (seldom a 4th is needed) it roars to life. No dead batteries, no bad wiring, no generators not generating, no cutouts not cutting in or out.
It's my only non green tractor and by comparison it's a miserable old bugger to sit upon & use but hey, the price was right, it's trustworthy and everybody needs to tend to an orphan once in a while!
Oddly, my only tractor with battery ignition is also my only diesel.
