Anonymous-0
I recently bought a Major Diesel, and it wont run. Its getting fuel through the fuel pump, through the filter, into the injector pump, but wont pump through the top of the injector pump. The pieces on top of the injector pump where the fuel lines exit to go to the engine dont allow fuel to pass through. If you take them out along with their respective springs etc, fuel will flow from the pump out the open hole, place them back in, fuel wont flow. Is the injector pump not putting enough pressure to move the springs to allow fuel to flow out, or is the main fuel pump too weak to pressurize the injector pump enough. Also, if it is the main fuel pump, I saw pumps for the Fordson Major listed on this sites store, its the pump with the glass bowl on top. Is it for gasoline majors, or does it work for diesels too? Thanks for the help, Greyson
