Ellis Kinney
Long story/history. Farmall M tractor, bought in 1984. When I bought the tractor the exhaust pipe was welded poorly to the manifold. Through the years I just left it alone. Three years ago I bumped a tree limb gently but it broke the weld. I worked on the threads diligently and got them to accept a new pipe nipple. I epoxied the pipe nipple in using JB Weld extreme heat for pipe dope. It has held for three years but is now loose again. I am sure the threads will still be somewhat good but not like new of course. Is there a better epoxy product that someone has knowledge of that will work under heat?
I am a welder by trade and have experience with cast iron and nickel rods. Would you just weld it back in again? I am a little worried about getting a crack in the old cast manifold.
The other option of course is to buy a new manifold. I really don't want to do that because of breaking off a manifold bolt or not getting it torqued back correctly. I am not a good mechanic.
Thanks, Ellis
Thanks, Ellis
