MANIFOLD "SWEATING"
It generally happens in colder weather but when the temperature and humidity are right it is caused by the air cooling as it goes through the carb venturi. When the engine warms up and heat gets around the manifold it will clear up.
And welcome to the forums.
To add....
You can run it until it is somewhat warm, shut it down until the frost thaws, start it & go. If it's warm out, it can help keep it from happening. But not always.
Otherwise you'll have to build a heat riser out of some tin to keep heat there.
Mike
Cold intake air is more dense = more oxygen in the same CF of air. That's how it works for turbocharged engines anyway, that's why they have an after-cooler. For a gas non-turbo engine it might make it run leaner until the ice melts, but that; why it has a choke cable. At least that's how my old Super M did.
My goodness,in the Alabama humidity we have seen ice on the intake of this Ford, baling hay , on a 100° f day. Absolutely nothing to worry about. It kept on spitting out bales 😎.
Someone told me the problem is a little worse with gasahol
Oh my goodness. It's not a "problem" 😱........ example, have you ever opened the drain valve on the bottom of an air compressor and let the air out? If there is moisture it can and will turn to ice. Even in Alabama,in the summer,on a 100° day. It's the venturi in the carb making the air that's being sucked up cold. It's not a "problem" 🧐 rant over (for now)🤬
On my 1951 M the "neck" of the manifold just above the carburetor is sweating water (condensation) what is my problem? Thanx
Increase in Velocity = a decease in temperature...throw in some humidity....drop the dew point..bingo....frost on the intake.
The above happens on my CASE 930 Comfort King,six speed.
Do not be concerned with your ...
