Manual Trailer Winch Recommendation
cowplop
I've recently purchased an 18' trailer and would like to mount a manual winch on the front to help load tractors, implements or whatever. I don't need a big electric job, just something to help save my back! I'd like to find a manual crank-type winch with dual speeds and a free-wheel feature to speed cable playout. Probably about a 2,000 lb. capacity. Any suggestions of brand, model or supplier? Thanks!
There are 2 popular brands: Fulton and Cequent, here are URL"s to each (both are the 3700 lb models)
Fulton:
http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?R=200330569&storeId=6970&productId=200330569&cm_ven=natural&cm_cat=netconcepts&cm_pla=Google&cm_ite=hand%2Bwinch
Cequent:
http://www.southwestwheel.com/store/p-729-3700-lb-two-speed-hand-winch.aspx
There are others but with their price you could get an electric one.
If interested here are 2 made by Thern:
http://www.southern-tool.com/store/thern_m452-492_spur_winches.html
Go to surpluscenter.com and check out the selection of winches. All kinds of other good stuff for projects also. HTH Jf
One of the most important things it must have is a hand brake built into it .
Reason,
I live just off Lake St Clair in Michigan so were on the water alot. When your letting cable out fast due to weight on it , sometimes it gets away from you [brake].
If i had a dollar for evertime i have seen some get hit in the balls with the crank handle at the boat ramp i would be rich. The weight of a tractor or anything on wheels may give you the same "smack" ware you don't want it .
Have control of what ever you put on it !!!!
The boat trailer type are good. Two speeds and a pawl to prevent reversing so you can use it to hold whatever on your trailer. The pawl can be engaged or locked out as needed.
