Anonymous-0
OK folks, heres the story...A little over a year ago I had bought the 1105, with a leon front end loader and duels. It seemed like a pretty good tractor. I had plowed up 200 acres with a 4 bottom plow, did not seem to be a heavy pull for the tractor. The tractor burned a lot of oil so that winter I had bought a kit to rebuild the motor, 1000 clams for the kit , no big deal. So anyway, That winter I had the motor running like a top, I couldnt wait for spring to put it under a load.
Spring finaly arrived so I hooked up to the disc and started to disc. the motor run great! I was very pleased. I did about 20 acres then the tractor just would not move. I dragged the machine to the shop and tore it apart, I first thought it was the clutch that flew apart but it wasnt. It ended up being the spline between the trans and the rear end.
I found out later that the tractors were common for that spline to go out in them.
So heres my question... do you think I should fix the tractor or part it out, if I fix it would the same spline go out again??? Should I get uncle tony up here to help me fix it? dont know if I could afford all the cases of black label for him... sorry for the long story, any advice would be good
