jake lau
We want to pull with it. Was told by a tractor mechanic at our local shop that the 4 1/4" sleeves would work, but you need to machine the outside of the sleeve to make it work.
I have been on this same issue for the last six months. You will need to get custom sleeves and pistons if you go over 4". The biggest ones I have seen are 4 1/16", and sleeves are not available anymore. You will need to cut out the upper and lower block holes if you go over 4". Let us know what you find, because I have given up on finding those.
