Massey Ferguson 204
grandpa Love
Anyone know Napa or O'Reilly's parts
numbers for the coil, points,
condenser,cap and rotor? I googled. No
luck. Also should there be a dust cap in
here?
According to Standard Ignition, you will need distributor number. Looks like 2 different distributors were used on the 4 cylinder engines.
Yes, there is supposed to be a dust cap, and it needs to be there for the cap to fit right and proper rotor clearance.
There were several distributors used, really need the number off the distributor to get the right parts. With that number, you might find the part numbers online.
Looking at the YT parts, (not having the dist number) nothing appeared to match, but they could have them.
I doubt any local auto supply will stock them, even if you give them the part number. Maybe Tractor Supply if you take them in and match them up. Don't expect real high quality from there. Compare everything carefully, especially the rotor. Save your old condenser!
Be careful replacing the coil that you get the right one. need to find out if the tractor has a resistor or resistor wire. To find out, turn the ignition on, put your volt meter from the + coil terminal to ground. Ground the - terminal. If the voltage stays up near battery volts, it does not have a resistor. If it drops to around 8-9 volts, it has a resistor. Choose your coil accordingly. Be sure to check the information printed on the coil can itself, not the box. They are often miss boxed.
Steve I need more help on your statement about the coil, working on an IH scout and having a hard time determining what coil to use. You say" it it drops to 8-9 volts it has a resistor." So does that mean I NEED coil marked NO EXTERNAL RESISTOR REQUIRED.?
jm, if a coil is labeled "NO EXTERNAL RESISTOR REQUIRED", that means it works on full 12 volts.
When I said "it it drops to 8-9 volts it has a resistor." I mean the vehicle wiring is equipped with a resistor.
Coils can be a confusing issue, lots of different values, and it's done with the internal windings. There was one exception, a Chrysler product I believe, made a coil with an internal resistor for a short time many years ago, not much chance any of us will ever deal with one.
For simplicity, we'll stick with the typical point type, standard performance, stock factory ignition system used from the 20's through the early 70's.
For your Scout, first you need to determine IF it has a resistor in the primary coil feed from the ignition switch.
There were 2 ways that was done. Either there is a visible white ceramic resistor, sometimes on the firewall, sometimes on the engine near the coil. Or some used a resistor wire hidden inside the wiring harness between the ignition switch and the coil.
To determine IF it has a resistor, ground the - terminal of the coil, have your volt meter ready, turn on the ignition and check the voltage at the + terminal of the coil. If there is a reading around 8 volts, there IS a resistor present on the vehicle wiring.
If the reading stays up near battery voltage, there IS NO resistor on the vehicle.
Run your test quickly and turn the ignition back off. Leaving it on will overheat the coil, even possibly burst it!
Now that you know if it has a resistor, or does not have a resistor, you can select the proper coil.
A NAPA IC14SB is a standard 12 volt, 3 ohm, no resistor needed coil. If your Scout has no resistor, this one will work.
A NAPA IC7SB is a standard 6 volt, 1 1/2 ohm coil. If your Scout has a resistor, this is the one you need.
The NAPA numbers are just a convenience, not promoting them, just an example. But whatever you buy, if you do buy one, be sure to open the box and check the part number printed on the coil itself, don't go by the box or what the counter tech hands you. Coils are dinosaurs, they commonly get shuffled from store to store, reboxed, restocked, recataloged. Just be sure you get what you ask for.
Hope this helps, email is open.
The points appear to be the same as a Ford 300 in line six, and likely some tractors. Compare them to Blue Streak FD8081. If so they should be able to look up the condenser for the same engine.
Not all distributors had dust caps. How does the cap fit on the distributor. If it sets tight to a locator and the clips snap on firmly, it may not require a dust cap.
Take a look at the kit in this link from the YT store. https://www.yesterdaystractors.com/MFDISTKITA_Tune-Kit-Tisco-Distributor_5039.htm I think there is a possibility you have one of the T*I*S*C*O aftermarket replacement distributors. One of these was discussed on the Massey Ferguson Forum a while back. Does the lower body look similar to this one?
That is a replacement distributor that was sold by Tisco. Like some have said, the internals are the same as Ford. I believe it was designed for a Ford, but was modified to fit the Continental used by Massey, after Delco stop making distributors.
