Massey Ferguson Disc
I have a Massey Ferguson(at least that what the decals say) disc, 8ft, 3 point with a tubular frame. I haven't been able to locate a serial and model # tag. Where would be the most likely place for the tag? Any idea on what model I have?
Thanks Lefty
I forgot to add that it has 2 levers on the front of the dics similar to those on a pull type plow to adjust the cutting angle of the gangs
Lefty, It should be a #22 or 25. If the gang bolts have a plate with 2 holes(for special wrench when taking apart)and the heavy nut is a
castle nut with cotter key it is a 25. If the
gang bolt is "wedged"into the cast bumper and has
a strip to lock over the nut it should be a 22.
They all originally had a model and s/n plate when new. Chuck
Chuck
Thanks for the help. I'll look today when I'm by the disc. Also do you know where on the disc they put the serial # tag?
Thanks Lefty
Look like this'n? This is a model #25. (Best 3-point disc ever built, any brand. Just ask anyone who's ever used one!)
Serial/model# plate WAS on the 3-point mast. MOST fell off.... Mine's been gone for years.
