Massey harris 101super
I have a 1940 Massey harris 101super that i want to narrow but i cant move the wheel hubs i have removed the ring of wire keeping it from moving. But i cant move it tried to spread the hub and soak it in
penetrating oil but no luck i have hit it with a 10lb sledge hammer and it wont move any suggestion?]
If it's like the Deere ones, you can try taking the hub clamps off and then driving it around a bunch. I'm not 100% familiar with that clamp setup.
I had a pair on a 101 MH junior where the hub was the inner wheel that the rim bolted to, sounds something like u may have!! I struggled with them for months!! I even got long drill bits and went in and drilled out the key ways!! If your wheel center has holes for weights or if it just a hub like 44s (and most all models used) use redibolt and a heavy piece of iron across the end of the axel and run redibolt they thru the iron and hub and tighten, making it a puller! I did this and left pressure on it CONSTANTLY, still took considerably a lot of pounding with a hammer before they even began to move!! Didn?t think they were ever going to move but eventually they did!!! Good Luck! Takes a lot of patience!!!
