Melted battery lugs
Old560
Son was doing some work on his truck had the starter disconnected reconnected it test drove it everything is fine. got in it this morning and this is what he found. Any ideas what would cause that to melt. I havent looked at it yet but something mustve shorted out. Says he had the clap tight.
looks like a dead short and she was welding away. did you remove that ground cable or it flew off?
Did it have Zero dash lights and zero key to start, or did it have dash lights, then nothing when turned to start? If it happened when the starter was making effort (key to start) the starter could be shorted internally, or the cable touching ground. If it happened over night it is likely the short to ground of the cable. I think that the clamp is bogus and possibly contributed to the melt. Using a 125watt electric soldering iron the post can be rebuilt. and filed down. If it actually tried to crank, the clamp is at fault. Soldered on real clamps can be purchased. Jim
Check if the cable got against the exhaust manifold, after his test drive insulation melted through and caused a dead short. Luckily, to a degree, the terminal to post connection must have been a little iffy and started arcing and it continued until the post melted away. If that would not have happened the truck would have probably burnt. Ultimately due to the main battery cables getting hot and losing their insulation shorting other wires around them out a eventually catching fire.
The old 24 volt John Deere systems would do that if a the connection got loose you would hit the starter button and fry the battery post
If the starter drive stuck that could happen.
Note that it is the NEGATIVE GROUND terminal that melted, and the positive terminal doesn't show any damage. That's probably because there was enough corrosion inside the clamp to make it the high resistance point in the circuit.
Look close, thats a dual battery setup, diesel pickup. It happened to the neg terminal, so rubbing thru to ground didn't happen.
what did happen was that the other battery neg terminal was not making good contact due to corrosion between the post and terminal.The one post that melted was carrying the whole load.
Terminals need to be electrically tight, as well as mechanically tight. If one side of terminal or clamp was corroded the all the amperage
was the cause of the hot spot on that battery.
Keep them clean!
Beagle
Sorry, I was wrong about that being a dual battery setup, But that is where I have see that happen the most. My aplogies.
Beagle
Ive seen that happen often over many years due to corrosion and resistance causing extreme heat (I Squared R) and/or there was excess current draw due to a starter/solenoid problem or other bad/loose/corroded/resistive connections. On many old tractors in extreme cold weather Ive seen starter solenoids stick closed causing high current that melted cable connections and lead battery posts OUCH lol
John T
Mark
Your explanation sounds very logical.
Oxidation and high currents,
Only one problem, Doesn't most of the time oxidation occurs on the + terminal?
I guess a vented battery both terminals can oxidize.
Went back and looked at battery. Looks like a lot of electrolyte leaked out and ran to the - terminal. You are right. You are the man.
Yes, that has been my experience. But it looks like the positive cable has been replaced, while the negative appears to be OEM.
I agree, kid at work put new batteries in a Case loader, never cleaned or really tightened the cables, first start took one post off level with the battery. $200 mistake, I laughed since they hired the fool as a mechanic but wasn't close to even being handy.
That ground clamp might have been tight on the post.
But that clamp does not appear to have been shiney clean on the inside. But that could be smoke and heat discoloration.
Terminal on battery may have needed to be shaved to get shiney clean and remove pits.
Wondering if when key was turned it was cranking normal, struggling or was there a few seconds of delay before it did start cranking.
Note, cranking is not running
I had basically the same thing happen today on my Massey 65. The positive cable rubbed through on the fuel tank seam and burnt the negative cable end off. I would assume that the connection there was somewhat loose or not as good as the other. The positive cable looks fine(other than the rub through).
