metal bandsaw blade
randaleky
just recently purchased a EMERSON 10 horizontal
metal bandsaw, and can not find any information on
the blade size. i know it uses a 1 inch wide blade
and should probably be around 8 teeth per inch, but
i am not sure on minimum and maximum length. any
help appreciated.
Don"t know anything about the folks at the link, but they have a pretty good blade selection chart on their site. Looks like there are several Emerson 10 saws with a 5' long blade.
As far as teeth per inch, it depends on the thickness of material you are cutting. Rule of thumb is you want at least 2 teeth in the material at any one time. In other words if the material was 1/4 inch thick you would want at a minimum a blade with 12 TPI. If your cutting anything thinner then you need to add to the TPI count. If you do a lot of thick material then you can go to a lower tooth count, but then you need to keep one blade for the thinner stuff and one for the really thick stuff.
I think the one I"ve got on my saw for general cutting is a vary-tooth with a 12/14 TPI count, and then I"ve got one with an 8TPI count for the thicker stuff.
Hope this helps.
Blade chart
First, run the blade tension adjuster down to nearly bottom, then
run a string around the wheels, and then measure how long the
string is in inches. Then go to enco, mcmaster-carr, msc, etc. Easy
to find, usually.
