called the local co-op to inquire about filling my tractor tires, they said it's $3.95 a gallon. when i asked them if they used CaCl or antifreeze or what they said no, they use methanol. this doesn't seem like a good idea to me. seems like an accident waiting to happen you guys ever heard of this?
after talking to them and hearing the price, i went and got a transfer pump and plenty of sierra "safer" antifreeze, i'm going to do it myself. my question is, should the tire bead stay on the rim, or will it likely pop off when i let the air out? i've had tires pop off the rim before and it was a pita to get them back on. my plan was to jack it up a little, let the air out, and lower it until the tire is resting slightly on the ground, so the weight of the fluid won't break the bead. then fill it, and top off with air.
correct/incorrect?
Matt
correct/incorrect?
Matt
