metric banjo fitting
sherburne
My JD410 backhoe, built in Mannheim Germany, chafed the pressure in hose to the hydrostatic unit. Couldn't find a metric bite style fitting or adapter, so I cut the hose and put a Gates jic fitting on, against most of the advice on this board. The hose was the same i.d. as Gates, and I decreased the o.d. on a lathe to Gates dimension. The din spec on the hose was higher than Gates so I didn't worry about losing a little rubber. The crimp speced out fine, and I put 3000 psi from my pressure waqsher to it. Fine.
Now the problem. The hose goes to a banjo type fitting on the steering unit. JD part #AL28252. Obsolete, nla. The banjo is a cube about 1.25" that fits over a hollow threaded stud on the box. A 16mm 1.5 bolt goes over the banjo into the stud. Its 27mm hex head is under cut to create the seal.
I've misplaced the bolt.
Anyone know what this fitting is? Where to get one?
Thanks.
