MF 1085 opinions
Croh
I have one of these tractors in my area that has 4600 hrs on it. The guy says its been well maintained. Is the Perkins in these pretty fuel efficient and dependable? It"s between this and an Oliver 1855 with 2400 hrs on it. I"ll be puling a 6/11 JD 1780 Planter/Splitter. Thanks for the help!
our massey ferguson 1080 has the exact same engine in it. I posted on your post on the oliver forum as well. But anyways the engine runs good and sounds great but i wouldnt call it efficient.
We had one for 15 or more years.We worked it like a 100 hp tractor,great on fuel,but it just wasn't capable of working that hard.We spent thousands upon thousands keeping that running over the years I don't know why they kept it so long.I guess after they spent so much on it each time,they kept it to get their money back out of it again and back to squear one again.Head gaskets every year,rings and gaskets every second year.The transmission even locked up on ours once and cost us $7000.Replaced the multi power a few times to the tune of $1000.A neighbour has the same one still,always worked it like a 65 hp tractor and never had it apart.They are kinda like an old Oldsmobile HO Quad 4,can run with the much bigger dogs,for a short short while.If you need it to do 165 MF work,you'll be fine,if you are going to work it hard,you will be money ahead getting a 6cyl tractor,1105's were much better tractors for bigger jobs.I know I'm repeating myself for the third time lol,but medium work,buy it,heavy work,steer clear,jmho,pd.
Ditto on what Phillip has to say. Buy a 1105 and you will have something. This comes from a 1080 owner. My 1080 has served me well but has been in the shop a fair amount of time. It has been retired to yard duty and seems to hold up now.
Merle
I agree with the comments about the 1080/85 being a good med. duty tractor. If you want to do some serious field work, look at a 1105/35. Much more tractor, including hydraulics. The 1855 Oliver is a nice tractor, only problem is you get a Waukesha motor. Sorry guys, they scare me, seen too many with "ventilated" blocks. If you could get the 1855 with a Perkins, it'd be fine. If you want a cab, look at the two and you'll know very quickly which one you want. I've driven both the 1080 and 1135, the 1135 is in a totally different league. Don't ignore the 2-85/105 Whites, you get the 6 cyl. Perkins with a very reliable drive train, over-direct-under shift on the go and a reasonable cab for a reasonable price. The 2-85 would be a bit ahead of the 1085 power wise with a much healthier drive train and the 2-105 would be very much like the 1105 for power.
My 2 cents (sorry Massey guys for the White comment, but I have driven a 2-85 for years with no big problems, just had to throw that in...)
Bruce
Your quite welcome.I hope I didn't scare you.If it's in great shape and you decide to take it home,If it was me,I'd take it to a shop that has a dyno and instruct them to set it at 70 or less hp.It may cost you a few bucks now but it will make some nice reliable tractor out of it.We had ours brand new and the shop set it at 95hp and you know the rest.Those little engines will produce quite abit of hp for the size if turned up.Dad said when we got ours,we almost bought an 1105 and the sales person (they were new than and didn't know the outcome) said why spend this much on the 1105 when for that much you can get this much hp from that and save quite aibt of fuel.
I have one of these problem child's too. Ok to haul manure but don't work them hard. Five head gasket's in 4500 hour's. Tried different head bolt's and head with no luck. PTO brake stick's all the time too so PTO don't stop. Good wagon haul tho and starts good in cold weather.
