MF 1135 axle movement (Float)
Anonymous-0
Hope you can help with some info.When operating 1135 driving along the side of steep hills I hear a crating noise in rear axle area.Last year we removed right side disc,piston and plates which were badly damaged and left out of tractor.Cleaned out as much metal as possible without removing left axle housing.Noted noise still when operating on the side of hills but not as bad.Today removed left side housing and brake assembley only to find disc in good condition and slight wear on brake plates due to metal.Is axle moving causing wear etc and can this be adjusted ? Axle bearing seem ok but haven't removed yet.Regards Peter
