I installed the real power steering pump on my MF-135 not used for power steering
but to operate the snowblower shute turning and tilt also top link cylinder.
It works perfectly. Since the cylinders are double action the reservoir on the pump is OK.
To use single action cylinder(s) I plan to plumb the succion side of the pump in one of the drain plugs of the transmission
and the return to the plug to the hyd top cover plug to use transmission/diff as a reservoir.
I know that if it was a straight pump with no reservoir it will work
but... what will be the behaviour with the pump with reservoir ?
What do you think
Thank you in advance
Bart
What do you think
Bart
![cvphoto143928.jpg](https://www.yesterdaystractors.com/cvphotos/cvphoto143928.jpg)
