Hello folks, I have a massey 135 diesel with the AD3.152 perkins 3 cylinder. It came into the shop with a blown head gasket, radiator bubbling, so Okey, let's change this head gasket.
I drove it into the shop and tore it down.
I changed the head gasket, purchased a NEW head with new valves and all that jazz, put it all back together by the book, set the valve lash by the book-.012 cold.
Go to start it and it backfires once then stalls. After some exploration I realize that the exhaust is SUCKING, not all the time, more a push-push-suck, although it is happening to both exhaust ports(with the manifold off, valve 1 and 2 on first port and valve 3 on second) indicating that its at least two if not all three valves doing this.
I have tried loosening exhaust valves, a lot, with little to no improvement. Timing seems on since I am getting no push at the intake manifold, and when I had the head off the TDC mark was perfect with number 1 being flush with the top of the block and the camshaft had all but #4 and 6 lobes facing down.
Please help tractor forum!
