MF-135 Won't Start
smithjr31
Keep in mind, my mechanical skills are amateur at best. I have an MF-135 Gas, with a Continental Z-145 that I purchased about a year ago. I used it for a couple of months blading snow on the driveway then used it all summer mowing my yard. I never had a problem with it starting. I last used it in September for mowing and I just now tried to start it and nothing happens. No clicks or anything, but the gas gauge does move when the key is turned. I charged the battery and it has a full charge. From what I've been able to research, it could be a rusted out connection or the starter solenoid. I've read that you can use a voltmeter to pin-point the problem but am not really sure where to start on that. I have posted pictures that will hopefully help. Thanks for any advice you can give me, the more details and "dumbed down" the better.
Photos on picasa: http://picasaweb.google.com/jrsmith31/1232011?authkey=Gv1sRgCJGLkprjuMbTFw#
Are you sure you have the small shifter lever in neutral? If yes then
I would check the switch on top of the gearbox ,just behind the
airfilter box and below the battery.There will be 2 wires leading into
the gearbox switch with a rubber cover. pull up the cover and take
the wires off the switch and cross them or join them together or
even test at this point to see if you are getting power when you
operate the switch.If not, your problem is in the key or push button
switch or somewhere in between. Its is really a matter of using a
simple circuit tester (the type like a screwdriver with a bulb inside
and an earth lead out the top!) to find where your power stops.
Both shift levers are in Neutral. I used my volt-meter and there is power at the switch on top of the gearbox. Where should I test next? Thanks.
As long as it's in neutral, you can jump the starter with a screw driver on the selenoid. Not reccomended for everyday use, only diagnostics. If that makes it start, then your battery is good.
Again MAKE SURE IT'S OUT OF GEAR!!!!!!!!! - Don't need anyone getting run over trying this.
Donovan from Wisconsin
The trick with the screwdriver worked, I got it running! Thanks. Does this mean I need to replace the solenoid? What would cause this to go bad by just sitting in my garage over the last few months?
We had this problem with a 135. We were doing some fencing in a pasture, the tractor was hooked up to a trailer full of fencing gear. While dad and I were not looking some curious calves had been messing around ( as they do! ) and one had pulled the wires out of the safety switch. No real harm done, it was just a case of plugging the wires back in.
Was there power on both sides of the switch. When
it was in neutral there need's to be. For it to
work.It will always have power on one side.
Yes, I would replace the solenoid. I've got three Masseys and every now and again the starter solenoid just gives up. It's a pretty inexepensive repair and takes no particular mechanical skill, especially if you are the one removing the old solenoid so you know what wires go where when you install the replacement.
I get my replacements from the local Advance Auto as it is closer than the Massey dealer. They are usually a next day item.
Thanks for all of the great advice and responses. I took all of them in to consideration and went to it with a multimeter. The problem ended up being a rusty connection on the solenoid with the wire coming from the switch on top of the gearbox. Used a wire brush to shine the connection, washer, nut, and post, and then the tractor fired right up. I think every other connection on the tractor is rusted at least some too, so hopefully I'll get around to cleaning them all on a rainy day.
