MF 165 lift problem
C. Burnett
A co-worker has bought a 165 with an industrial loader on it. He says the 3pt will only lift his bush hog about 8 to 10 inches off of the ground. He has changed the filters. Is it time to look towards the pump or is there something else to check first?
Is the oil low? If not, it may just need the 3 pt. controls adjusted. Someone like David P will probably be able to tell you what to check. Dave
Hi,
The cause of this is likely to be excess end float in the control spring adjustment.
Disconnect the top link. Fully lower the DRAFT quadrant lever. Push and pull on the rocker linkage where it goes into the hydraulic cover. End float should be zero. If there is end float present the spring assembly will need to be removed, freed/adjusted and then further adjusted when fitted to the cover.
DavidP
Is it possible that just the special nut, on the end, that holds the draft plunger in is loose? I only mention this because I had some work done on my tractor several years ago and the new service manager at the dealer was trying to tell me that the spring assembly is adjusted according to a measured length, which is wrong. I think it was you (David P) that explained the spring is set just to take out any freeplay, when I had to replace the draft plunger and yoke a couple years ago. The new service manager at the dealer also said it was OK to have the top link mount flop all over the place. I talked to a good MF mechanic and he said to loosen the set screw and tighten the special nut just to take the slop out of the top link mount. The dealer that had no clue had new owners and they went under in less than 2 years! Dave
Hello Dave, On reading your reply my first question was going to be "is this service manager still in his job"?
Yes, it would be possible to adjust the control spring nut but this is no certain way to carry out the adjustment. I have seen the spring with 1/8" or so end float due to wear and tear. The only sure way is to strip it and adjust the plunger so that the spring is stiff to turn by hand. Then refit the assembly with a new boot if required. I had a similar instance with a 135 some time ago. In the UK we have a hay tedder called the 'Haybob' made by PZ in Holland. If you do not know the name it is a two-rotor machine covering some 10 feet with the tines thrown out. The 135 would only lift this about one foot off the ground. When the control spring was adjusted it worked 100%.
Happy New Year
DavidP
When I replaced the plunger and yoke, the 3 pt. lifted better. I think because the slack was properly adjusted, thanks to you. The new parts were heritage parts and only cost about $65 for everything. The only thing I forgot was to get a new boot but mine wasn't totally bad and I have a cab on the tractor. A long time mechanic at that dealer left because of this new service manager. For a service manager, he didn't have a clue. The other mechanic went to another MF dealer to be the service manager there. He knew his stuff and had worked on my tractor in the past. He got tired of fixing and is now in sales but he's the one I usually talk to if he's in when I go there. Dave
