MF 165 Power Steering
Kent, Most likely it is the little hex turnbuckle
above the steering cyl. For now adj. it VERY
SLIGHTLY one way or the other and balance it out.
If that is it you may want to take up play in the
little pins and clevis'. Rather than replace we
used to drill slightly oversize and put in new
pins. One unlikely thing would be that the tie
rod assy is unscrewing from the cast curved strg.
arm underneath(there is a small rubber boot)and
that is catching. It has happened on 65's and I
don't know if the same pertains to the 165. Chuck
