DougH - MF 20 Ind
Hi all, I am in the process of going through a 1976 Massey Ferguson 20 Industrial that I just bought. My 3 pt. Was acting very jumpy and not raising all the way and the transmission /hydraulic fluid was very milky from apparent moisture so I am changing it. In the process I opened the little triangle cover on the bottom of the pump housing to clean the model MK3 pump strainer (which was badly plugged) and I found a light duty tension/ extension type coil spring about 1/4 dia x 1 long with hooked ends with one hook broke off. Any idea where this spring broke off from? Thanks.
I cant send a photo yet I am told because I am new to the forum and need 5 posts to get permission for photos.
Doug
Doug
