MF 204 3 point hitch
Dave_1248
hi,
I'm curious about the workings of my 3 point hitch.
I recently bought a non running mf 204 and have finally got it running. The 3 point hitch works, but something funny is going on with it. I hook up to my box blade, and it doesn't want to lift the blade. I put it in gear and rev the engine but still no luck. It seems that if I step off the brake and let the tractor move, it will lift the blade. Is the pump on this tractor attached to the engine in a way that it will only work when the wheels turn? I'm used to a tractor that the 3 point hitch works anytime the engine is turning.
Also does anyone know what hydraulic ports are under the cover plate on top of the lift arm cover? Got pictures?
Dave
Your pump only works when the reverse-o-matic is engaged, one of the drawbacks of the 204 & 205. Also if you have a PTO that will reverse direction when you reverse the direction of the tractor, so if you use it I recommend you get an over-running clutch for the PTO.
I had the tractor in gear, and wanting to move, but was standing on the brakes(really didn't want to tear up the ground next to the garage). I'm guessing this isn't enough to get it to pump?
I'm thinking about hooking the loader pump into the 3 point hitch via that block on the cover. I'd use the transmission as the sump for the loader at that point. Then either let internal pump freewheel, or use a check valve setup to use both pumps. Anyone ever attempted this?
The pump drives off the transmission so if the transmission input shaft isn't turning, no hydraulics. Try putting the high-low lever in neutral and see if it will lift.
The lift on my 204 was not wanting to lift until warmed up. I replaced the fluid which was "milky" due to water mixed in with the oil. I assume due to condensation. Seems to have resolved the issue.
