arno
Hello all, I'm needing to overhaul the trans in my 1984 mf 240. It is a U.K. biult tractor. Standard 8 speed not the multi-power.Can some-one tell me if parts are easy or not to find. Thankyou in advance for any help. I live on Vancouver Island in western Canada.
Shouldn't be hard to get parts at all. Most likely uses the same trans. that has been used for years on other tractors. Why does your trans. need an overhaul? Dave
Hi Arno,
135 Fan's question would have been my first one. Has the tractor done high hours, broken something or just sounding noisy perhaps? Many parts will be available from your nearest Bepco supplier. 8-speed constant mesh and 8-speed synchromesh transmissions are listed for the 240 so you will need to be sure which type it is.
DavidP
The tractor has just over seven thousand hours on it.I dont really know what kind of work it was used for.I bought it 2 years ago for makeing hay mainly.Sure it never had a loader on it. The trans got jammed in fist gear -shifter looks warn. I don"t have the tractor split yet but have the dash + steering stuff removed and can see in from above.Lots of busted teeth -looks pretty warn to me.Seller said it had a brand new clutch but it always seemed you had to grind it into gear. I am deaf and can"t say if it was noisy or not.Thankyou for your replies.
Hi Arno,
If there a lot of teeth broken maybe on more than one component maybe a complete second hand box or even an MF replacement might be worth considering. The problems that you may find are that pieces of teeth, even splinters have caused more damage than might be initially visible. They may wll have found their way into the bearings as well. To make matters worse the pieces may also have found their way into the back end of the tractor and possibly damage the final drive components. The Ferguson pump will be reasonably immune to this other than the filter perhaps picking up something. I would certainly suggest a hyd cover and pump removal.
You can then assess whether you need to go any further.
DavidP
