Joe Snodgrass
I had an incident with my 1979 MF 255. I was tilling with a 6' 3 point tiller. I struck part of an old stump that was below the surface that could not be seen....(in a previously tilled garden). Long story short, I had one heck of a time getting the tractor out of gear, the PTO out of gear and the 3 point lifted to get the tiller dislodged from the ground. I would engage the clutch enough to see if I could get any of this done and shut the tractor off 3 times in the process to keep the clutch from overheating. Believe me, I did not ride the clutch anymore than I had to as I did not want to damage anything more than it already had been. Finally I got the PTO disengaged while the tractor was not running, got the tractor out of gear and started the tractor and lifted the tiller from the ground and drove out of the garden. I could smell the clutch was hot and it didn't take much to get it to smell....only a very few seconds maybe 5-10 seconds total in all this process. Anyway.... my question is this: THE TRACTOR SEEMS TO OPERATE FINE. GOES IN AND OUT OF GEAR FINE AND THE CLUTCH DOESN'T SEEM TO SLIP.......BUT AFTER USING IT FOR ABOUT 20-25 MINUTES I CAN OCCASIONALLY SMELL A BURNT CLUTCH TYPE OF SMELL. IS THE TRACTOR OK TO USE OR SHOULD I SEND IT IN AND HAVE IT LOOKED AT? I DON'T WANT TO DAMAGE IT ANY MORE. ARE THERE FLUIDS I SHOULD CHANGE? THIS IS A 2 STAGE CLUTCH TRACTOR.
ANY HELP ANYONE COULD AFFORD ME WOULD BE GREATLY APPRECIATED.
