First, I want to apologize for not following up my prior posts, as "notify" does not seem to work. Second, sorry for the length of this recap.
I have a MF275 that belongs to a local non-profit ranch, which I volunteered to try to fix. It ran 10 years ago, but sat since.
I found that the diesel tank was full of crud, as was the lift pump and fuel filter. The tank was cleaned and the lift pump and filter were replaced.
I then re-built the CAV (3241F541) pump. I found that the inlet strainer, the poppet below it, and the entire top of the pump were all full of the same crud. The metering valve was also stuck, as was the governor mechanism.
Interestingly, the spring settings in the top chamber were NOT as documented for that part number. I left them where they were as opposed to where they should be per PN. Someone must have messed with it long ago.
The shuttles in the high pressure section were also stuck. After a thorough cleaning, the CAV reassembled according to documentation, and the pump "squirted" sequentially as hoped.
Re-installing it on the tractor, I still got no trace of starting - no coughs, no smoke or mist from exhaust, and not even any reaction to ether. After acquiring a compression test kit and fabricating a custom adapter, I found all cylinders had 210psi of compression. I know that is lousy, but I'm told it should at least run with those numbers, and maybe improve with a little exercise of the rings. I then tested all the injectors, and they all popped at about 2100psi, again not great, but probably okay. Reassembling, I still get no sign of life, so that leaves me with thinking the CAV is failing to provide the needed pressure. If I put my finger over a high pressure line while cranking, I can feel a tickle, but it doesn't force past my finger, which I'd guess should happen.
I'm not sure what could result in the CAV failing, unless there is some air trapped somewhere that is creating a cushion. I have cranked for many minutes with the injectors disconnected and all lines are squirting as expected. I primed the CAV as shown many places.
I haven't figured out how to hook up a gauge on the output, due to the myriad of various thread sizes, although I'll probably do that eventually.
My questions are 1) is there anything else that can defeat the CAV, and 2) there are many CAVs for sale (e.g. ebay) that claim MF275 compatible, but none share the last digit. Is the spring position more of a tuning issue than go/nogo issue?
