I'm working on brakes on a MF 300-- the cylinders were a little low-- actually one was low and one was dry. I filled and bled the brakes-- still not working. Probably a dumb question but what is the next likely culprit? Thanks
check the clevis bolts on the wheel cylinders they are brass and will brake and the wheel cylinders will still operate and have a good brake pedal if pumped up without leaking.
