Bob N.Y.
- Location
- Norway, N.Y.
I have a Massey 35, 2 stage clutch, no Multi-Power. I need to replace the transmission input shaft seals. I have I&T repair manuals. The manuals say in order to pull the input shaft assembly out, the front part of the lower shaft has to be pulled to allow the PTO driven gear to drop down so that it is out of the way of the upper shaft bearing carrier. I understand the logic behind this. The problem is there appears to be a snap ring on the lower shaft that prevents it from being pulled thru said gear. How is one supposed to remove that snap ring when we can't even see it or feel it?
