Hi I'm new to this forum, thanks for letting me join. I just picked up a MF1455, and needed to replace the rear pto seal. Once removed, it was apparent the bearing was shot and needs replacing. My problem is getting the pto shaft out of the tractor so I can replace the bearing.
I removed the seal, removed the snap ring, and now it won't come out. Diagram is attached. #14 is the seal, #15 the snap ring and #3 is the bearing. I was hoping the pto shaft would come out (with some work) and that I wouldn't have to mess with the gears. The shaft will only pull out about half an inch. Is there something I m missing? By the manual diagram it looks like it should pull out, the shaft and 2nd bearing (#11). Any help would be appreciated.
I do have the detailed service manual and could post pictures of disassembly if that helps someone. Much appreciated!!
This post was edited by wespx007 on 12/01/2023 at 11:38 am.
