MF 65 front weights
Ed M
Does anybody have a picture of a front weight bracket for a MF 65 ? I have a hard time turning when plowing and disking since the front wants to lift.Are there any wheel weights I could buy ? How about loading the front tires ?
Here is a picture of our MF 65 Diesel with the weight bracket on it. Some wear I have 4 front weights for it, there about 70 lbs each. Hope this helps you out. Bandit
Hey Banditfarmer,
Can i ask if the front weight frame is bolted on by four or six bolts?
I couldn't get the correct weight frame for mine so i have bought a second hand one from a 690 which i plan to adjust to fit.
I have the lower front panel off the tractor and can see four holes high up(2 at the side and two on front at the same level) i also noticed 2 holes lower down on the front axle kingpin housing and need to know if these are for a weight frame too.
any help is greatly appreciated.
thanks,
Alan
