MF-65 rear wheel
I need a little help once again. My MF-65 is in need of a rear wheel. The area around the valve stem is badly rusted out. This web site list two different wheel sizes. They are 10x28 and 11x28 wheel sizes. The tractor has a 14.9x28 inch tire size. Which wheel do I need??? Thanks...
Do you have the tire off the rim? If so, measure across the inside of the rim where the tire seats to find the rim width. If the tire is still on, you could approximate the width from the outside.
They are both too small. The 14.9 tire fits best on a 13 inch wide rim, but is ok on a 12 inch. What you have can be fixed with some new steel or a piece cut from a donor rim. Check back a few days in these pages for a similar post and answers.
