MF 65 throtle/governer?
Anonymous-0
I have been having problems with the engine racing. After finding/fixing the play in the linkage, I started following the I&T shop manually to put everything back within specs. I can get the engine to MAX at 2000+rpm but if I let go of the throttle the governor pulls it back to 1500rpm. Is this normal? The book does not say anything about this.
Not sure of the gas version but the 65 diesel has a friction disc on the throttle lever that keeps it from moving when set. It's not really adjustable-just some springs on it to keep tension. It should be a cheap part. Ordered 2 for a 165mf and they were only $2.50 each.
Mine has done the same thing for 25 years.I think that is normal.On mine the max throttle is about 3/4.When I go down the road and want a faster speed ,I have to override the govenor and hold the throttle.On mine when I plow and disk,I bring the throttle up to max and then lower it to where I need it.I think that is the way It may work.I am hoping in the future to totally rebuild mine before all parts dry up.It is a great tractor for what it is and simple to work on.Wish it had rear locker though.How is your backhoe setup working ? I just e-mailed you about that
Thanks. All I see on the parts book are the 2 spring on the throttle to governor arm. Are these two spring what you are talking about? I can see the outer and all looks fine. Looks like to get at the inner I have to remove the gas tanks to remove the linkage.
www.agcopartsbooks.com/EpsilonWeb/book.aspx?book=agco/690237
Goto Page: 22
20 184427M1 1 Spring, Compression (Inner)
21 184426M1 1 Spring, Tension (Outer)
no. On the lower end of the throtle lever there is an arm that pulls tht governer rod. theres another arm that hooks to the ballance spring which is on the left side of the steering box. under the battery rear and bottom of dash.
The new spring looks different than the one that was on it, probable came from a hardware store, before I got it. But still am having the same problem.
Any other idea short of replacing/rebuilding the governor?
