So... I thought I'd try the 135 plowing a bit of the snow we got recently. What I found, was the left tire kept locking up while trying to reverse. Touch of right brake, and it would break loose.
I didn't get any hint of this when I was test driving the machine. Only difference is it was colder now, slippery, and I had taken the rear weight box off. (really hadn't planned to try the plow this winter, but it's hard to resist a new toy)
Thoughts? Gut is saying a broken spring in the drum. Possibly just out of adjustment... I note that the parking brake ratchet will be all the way to the bottom if I just lock the left brake. Anything else that springs to mind? I didn't see anything common in the archives.
Also found I really wish it had the diff lock... Without the rear weight, it's a pig on roller skates, on ice trying to manage getting up our hills. Our JD300 did just fine with weight on the rear pushing snow. Both have good tread, but the JD has brand new rubber, and the MF is 40 years old... Next trip up there I'll be throwing the chains on the JD... Have to see if the chains from our 8N might be able to go on the 135.
