MF135 PTO shifter side cover
Anonymous-0
When removing the pto side cover, are there any grimlins I should look for. My book does not give a good removal procedure, only shows a diagram with componets. does the shift leaver come off before removing the cover, or does the leaver and shift fork all come out together????
If I remember correctly it all comes off together, you just have to make sure the shift fork goes back in the right place when putting it back together. Pretty easy job.
All comes off as an assembly. Put PTO in nuetral. make note of location of shift collar inside when you pull the cover. Make certain it's in the same spot before re-install, and keep lever in nuetral then too.
