Had one new. 4wd driveshaft went out in less than 1000 hours. Transmission growled so loud in some gears that I very seldom used those gears. Hydraulic pump filled the engine oil crankcase with hydraulic fluid the first time I used it. Ended my affair with MF.
As my handle reads, I've got a 294-4. For what I use it for , it is great. Bought mine used and it has 5800 odd hrs now. I think a dairy farm had it originally then a professional mowing service. Yes it is a Landini and parts are high through MF. Re did the starter and iginition switch recently. Selenoid though MF was 1 to $200. Napa $38. Switch $100 + , got an AutoZone for 10. Has a seperate pump for the loader. Lots of loader power. Yes the high range gears are a little whinny. You can hear if you leave the 4x4 in if you start down the road also.
Here's a pic of my MF294-4
